Powershell script not running IIS checks
I wanted to know if anyone was familiar with the CIS IIS benchmark scripts. Basically there is an environment set up task that runs and it pulls all of the powershell scripts out of the fixlets, downloads them to the server, runs them and outputs the results to a file. We had to make a few changes to some of the scripts to do recursive searching for IIS subsites. We have a handful of servers that for some reason when running the setup task wont download certain scripts. I have cleared out the content of the site in the BesClient folder to try and resynch the data. I cant find any error of the scripts failing to run. The scripts work fine for the majority of the servers.
