Power Management Dashboard Applicability - Mac OS X
The relevance on the ‘Enable Client Dashboard’ task from the Power Management site limits it to OS X 10.4 - 10.8. Any reason this hasn’t been updated to include current versions of OS X? Is BigFix Power Management fully supported on current versions of OS X?
More than likely an oversight. I’d suggest you open a PMR
I put in a PMR because Windows 10 wasn’t returning the correct values within Your Power Footprint and some analyses. They came back saying Windows 10 is not supported for Power Management and asked me to enter in an RFE. I have a feeling they will come back with the same thing. Within the RFE, I have stated that Power Management needs to be updated for all current OS’s including Mac OS X.
http://www.ibm.com/developerworks/rfe/execute?use_case=viewRfe&CR_ID=83305
