The Fixlet Debugger runs under the security content of the logged in user (i.e., you), BUT the BESClient service
runs under the LocalSystem security content. Since any analysis will also be evaluated under the LocalSystem context,
and because there is no guarantee that the HKCU registry hive is actually loaded when the analysis is evaluated by the
client, it could be expected that “No printer connections” is returned.
Have you looked into using "current user key of " object? The description is:
On 2000/2003/XP/Vista, this Inspector returns RegOpenCurrentUser. Under NT4, it uses HKEY_USERS<sid>. On these
systems, the Inspector may fail if run in a non-privileged context. Under Windows 9x, it returns HKEY_USERS<username>
if it exists. Otherwise it uses HKEY_USERS\Default. CAUTION: This Inspector will produce errors when run on a terminal
server where a user has logged off but there is a ‘keep alive’ setting on the user session. This is because there is
technically a logged-on user but that user’s Current User registry hive is not loaded. To avoid this issue, use a
qualifying ‘whose’ statement: current user keys (logged on users whose (active of it)) of registry
There is also a “Logged on User” object, which reads:
These Windows and Macintosh Inspectors return information about the currently logged-on user. With the advent of
Terminal Services and Fast User Switching, these Inspectors are designed to iterate over all logged on users.
• Windows Note: If Terminal Services are available (NT/2000/2003/XP/Vista) and enabled, these Inspectors iterate
over the active and disconnected sessions as returned by WTSEnumerateSessions. Disconnected sessions are those where
a user logs on, but is currently inactive. On Vista, the non-interactive session 0 (used for services isolation) is
not included. If Terminal Services aren’t available, the ACLs on the security descriptor of the “winsta0” window
station are examined for user logons. On Windows 9x systems, these Inspectors return the user session associated
with the registry value “Current User” of “SYSTEM\CurrentControlSet\Control” if it exists. Otherwise, if a shell
process process such as Explorer.exe is running, they return a single session associated with an unnamed user (which
occurs when the user cancels the 9x login dialog).
So in other words, make the analysis property only return information if a user is currently logged on, otherwise return
an empty string or something other than “No printer connections”.
If you look in http://support.bigfix.com/fixlet/documents/Windows%20Inspectors%2081_110706.pdf you will find more
information on these objects.
