Offer Box on user's machines pops up too early
(imported topic written by KimberlyNNH91)
I like to send Java updates out using an Offer Box to give the users the opportunity to finish what they are doing in IE and close it. I set the Offer Box up on Wednesday to deploy the software on Thursday morning and people started getting the “B” in the system tray on Wednesday afternoon. I expected and wanted the offer not to show up at all until Thurday morning. Did I miss a setting?
thank you!
Offers should appear when the offer is relevant and the constraints are satisfied… Can you paste the action summary results with the action configurations from the action?
(imported comment written by KimberlyNNH91)
Not sure how much of this you needed.
Any help sorting this out is greatly appreciated!
<?xml version="1.0" encoding="UTF-8"?> Java Runtime Environment 6 update 24 Available (JRE 6 Installed)
<![CDATA>
download http://www.sun.com/MANUAL_BES_CACHING_REQUIRED/jre-6u24-windows-i586.exe
continue if {(size of it = 16525088 AND sha1 of it = “e9d8c7c1f7722243a570a6d7f1e357aecb950679”) of file “jre-6u24-windows-i586.exe” of folder “__Download”}
// Note: update .exe will restart service automatically
if{exists running service “JavaQuickStarterService”}
delete __appendfile
delete stop_javaquickstarter.bat
appendfile net stop JavaQuickStarterService
move __appendfile stop_javaquickstarter.bat
waithidden stop_javaquickstarter.bat
endif
waithidden __Download/jre-6u24-windows-i586.exe /s /norestart
action may require restart “e9d8c7c1f7722243a570a6d7f1e357aecb950679”
Java Update
true
This is a security update. Please close Internet Explorer and click “take action” to install the update. Thank you
false
false
false
RunAutomatically
Interval
P1D
false
true
Do not open Internet Explorer until you see the message that the update has completed
true
09:00:00
14:59:00
true
PT22H3M10S
true
P30DT4H49M10S
false
NoRequirement
AllUsers
false
false
false
false
false
false
true
true
Security update
<![CDATA>
false
I can’t tell for sure from this export, but it might be that you used the “run between” instead of the “start time”… I think (but I will need to double-check) that the clientui should appear at the “start time”…
