Not necessarily a BigFix issue, but... (VBS runs but no work via BF)
All,
I have a VBScript that runs fine and works when run locally, but when downloaded and run (successfully) by a fixlet, the change that is supposed to be made by the script isn’t made. Any thoughts on why? Anyone know if there’s a VBS log file? (I can’t find one…)
The stuff:
VBS
Option Explicit Dim shell, net, result, compName, expDate   Set shell = WScript.CreateObject(
"WScript.Shell") Set net = WScript.CreateObject(
"WScript.Network")   compName = net.ComputerName   select
case compName
case
"CDSS2140" expDate =
"2013.08.22"
case
"CDSS2431",
"CDSS2432" expDate =
"2013.06.16"
case
"CDSS2376",
"CDSS2378" expDate =
"2013.04.06"
case
"CDSS1997" expDate =
"2013.03.07"
case
"CDSS2275" expDate =
"2013.01.17"
case
"CDSS2270" expDate =
"2013.01.12"
case
"CDSS2157",
"CDSS2158" expDate =
"2012.09.15"
' lots more cases, no case else end select
' Write out Warranty Expiration Date result = shell.RegWrite(
"HKLM\SOFTWARE\BigFix\EnterpriseClient\Settings\Client\Warranty Expiration Date\value", expDate,
"REG_SZ")
Fixlet
Relevance
true   Success Criteria This action will be considered successful when it runs to completion.   Action Script Script Type BigFix Action Script   download http:
//file.server/files/WarrantyExpDate.vbs waithidden cscript.exe WarrantyExpDate.vbs
BF log
At 16:52:23 -0400 - ActionLogMessage: (action 114494 ) starting action At 16:52:24 -0400 - actionsite (http:
//bigfix.server:52311/cgi-bin/bfgather.exe/actionsite) Command succeeded (Using download manager collected file) download http:
//file.server/files/WarrantyExpDate.vbs (fixlet 114494) At 16:52:25 -0400 - actionsite (http:
//bigfix.server:52311/cgi-bin/bfgather.exe/actionsite) Command succeeded (Exit Code=1) waithidden cscript.exe WarrantyExpDate.vbs (fixlet 114494) Not Relevant - Deploy WarrantyExpDate.vbs to unconfigured CDSS machines (fixlet:114494)
Your path to the vbscript is broken… Try instead:
waithidden cscript.exe __Download\WarrantyExpDate.vbs
The cscript.exe ran, which is why the line didn’t fail, but you can see it returned an error exit code.
Ben Kus
That was it… feeling stupid now. Thanks, Ben!
  • John
