(imported topic written by RichB91)
My If/Then statement for setting parameters for paths that vary by OS isn’t evaluating as expected. On a Windows (WinXP) test system, the parameters for the Unix portion of my If/Then statement are getting assigned instead of the Windows values.
Any idea what I’m missing?
In the QnA tab of relevance Debugger, I get this result:
q: name of operating system as string as lowercase contains “win”
A: True
T: 0.162 ms
In the Action tab, using the following:
// Set Path and File parametes for Windows and Unix
if {name of operating system as string as lowercase contains “win”} Then
Parameter “DirScripts” = “c:\Company_Tools\BigFix\Scripts”
Parameter “DirArchives” = “c:\Company_Tools\BigFix\Archives”
Parameter “DirLogs” = “c:\Company_Tools\BigFix\Logs”
else
Parameter “DirScripts” = “/opt/apps/tools/bigfix/scripts/”
Parameter “DirArchives” = “/var/opt/apps/tools/bigfix/archives/”
Parameter “DirLogs” = “/var/opt/apps/tools/bigfix/logs/”
endif
The output to the Client Log tab is:
STATUS: Running action…
Command succeeded parameter “DirScripts” = “/opt/apps/tools/bigfix/scripts/”
Command succeeded parameter “DirArchives” = “/var/opt/apps/tools/bigfix/archives/”
Command succeeded parameter “DirLogs” = “/var/opt/apps/tools/bigfix/logs/”
- Result —
Evaluation completed successfully!
