Nmap Scan Point
(imported topic written by jdefilip)
I’m trying to scan all IP addresses in my environment. I’m able to scan on the local subnet successfully. I tried
192.168.0-255.1-254
showing no IP addresses in the result. Any suggestions would be great.
Thanks!
(imported comment written by Adam_Case)
The Nmap scan point does not allow the syntax you are using. Unfortunately, you can only place a range in the 4th octet of the IP.
192.168.0.1-254
192.168.1.1-254
etc…
(imported comment written by jdefilip)
Thanks for the reply Adam_Case. If anyone has any other solutions that would be greatly appreciated.
