I access the environment through citrix vpn access, within the envrionment network I access the console and I have designated VM from which I target the nmap scan. action says completed but no lucks.
So from the scanning VM the machines you are looking for need to be on the same subnet (usually the same virtual network) so if they aren’t thats your first problem
@ AlanM, Ok. that means I need to specify the IP range or hostnames of those machines created…right?
Basically my requirement is to create a collection type baseline for newly discover machines and same can populate in the console. So that whenever I see the new machines I can deploy the BES Client.
