Need some help
(imported topic written by Boomer91)
I am having problems getting my relevance to work that looks for the value of a DWORD String (GinaDLL). This is what I have, I keep getting Singular expression refers to nonexistent object.
exists value “pssogina.dll” of key “Software\microsoft\windows nt\CurrentVersion\winlogon\GinaDLL” of key “HKEY_LOCAL_MACHINE” of registry
Where am I going wrong?
From your first sentence, it sounds like GinaDLL is the name of the value, not the key.
Does
exists value “GinaDLL” of key “Software\microsoft\windows nt\CurrentVersion\winlogon” of key “HKEY_LOCAL_MACHINE” of registry
return true?
If so, the correct way to check if the value of GinaDLL is pssogina.dll would be
exists value “GinaDLL” whose (it as string = “pssogina.dll”) of key “HKLM\Software\microsoft\windows nt\CurrentVersion\winlogon” of registry
There’s also the chance that you’re on a 64-bit system, and need to inspect the x64 registry instead of just “registry”.
(imported comment written by Boomer91)
It returns false when I run the QNA tool
The name of the Key is GinaDLL, the type is REG_SZ and the data is pssogina.dll. Does that help?
Chris
(imported comment written by Bill.Ehardt)
Try native registry, and possibly the as lowercase:
exists value “GinaDLL” whose (it as string as lowercase = “pssogina.dll”) of key “HKLM\Software\microsoft\windows nt\CurrentVersion\winlogon” of native registry
That resolved it. Thank you for the help.
