Can anyone tell me why when I put this in the relevance tester and evaluate I get “Error: This expression contained a character which is not allowed”
((exists KEY “HKLM\SOFTWARE\IBM\ADSM\CurrentVersion\BackupClient” of registry) and ((value “PtfLevel” of key “HKLM\SOFTWARE\IBM\ADSM\CurrentVersion\BackupClient” of registry as string as version) < "))
Ok I figured out that for some reason it works on the normal debugger. I was using Lei relevance tester. Weird. Anyway I’ve run into a new problem with the same relevance code. When I run it against Win2003 server 32 bit it works fine. When I run it against Win2003 64 bit it reports back false even though the exact same key is in the registry. Is there some difference between the 32 bit and 64 bit that would cause this? I’m stumped.
It is a little confusing at first. The Client is 32-bit and looks at the 32-bit registry with the “registry” inspector, whereas regedit shows the 64-bit registry and abstracts the 32-bit registry into the “Wow6432Node” branch. It’s part of how Windows in 64-bit looks like a 32-bit environment to 32-bit apps.
You will need to use different inspectors to access the 64-bit registry: x64 registry, native registry.
