system
November 19, 2010, 6:48am
1
(imported topic written by bunthoengacsthai91)
Hi all.
I need some suggestion about software deployment
I try to use command “msiexec /i FoxitReader.msi /quiet /norestart /LWAMOE c:\temp\install.log ALLUSERS=1” in Command Line cammand
it can deploy to server (server and console is in the same VmComputer)
but when I deploy to another computers it not wok properly. I can not find software that I just deploy. but it show status complete.
What wrong about my command? please give me some better ways.
Thanks a lot.
BenKus
November 19, 2010, 9:53am
2
Can you post the whole actionscript?
Thanks,
system
November 22, 2010, 10:37am
3
(imported comment written by bunthoengacsthai91)
Hi BEN
this command I use in Software deployment wizard
it just “msiexec /i FoxitReader.msi /quiet /norestart /LWAMOE c:\temp\install.log ALLUSERS=1”
that I fill in.
system
November 25, 2010, 1:06pm
4
any one can help me?
BenKus
November 26, 2010, 5:10am
5
Is that the whole actionscript?
This won’t work because you haven’t downloaded the file to the computer yet… Where does Foxreader.msi come from?
system
November 26, 2010, 5:35am
6
Have you packaged this using the software distribution wizard or just made an action with that command?
system
November 29, 2010, 10:04am
7
Sory for not clear question.
Let’s me try explain step by step
I choose software distribution wizard
I specify the name of task
http://www.uppicweb.com/x/i/iu/foxit01.jpg
Then choose the source file that I want to deploy
http://www.uppicweb.com/x/i/iy/foxit02.jpg
Select platform for task applicable
http://www.uppicweb.com/x/i/ix/foxit03.jpg
Target by OS only
http://www.uppicweb.com/x/i/ir/foxit04.jpg
Fill code that I ask
http://www.uppicweb.com/x/i/ij/foxit05.jpg
Confirmation
http://www.uppicweb.com/x/i/in/foxit06.jpg
And I have some confuse, if I miss to locate file directory in my code, why software ask the file souce in 3.
let me know, what step I mistake?
thanks
BenKus
November 29, 2010, 7:38am
8
Hello,
Thanks for the details. So it looks like you are trying to run FoxReader.msi, but the file that you chose to deploy was SSMSEE.msi. Where is FoxReader.msi supposed to be?
system
November 29, 2010, 10:03am
9
No, it just an example when I create task, software name not necessary.
think SSMSEE.msi is software that I want to deploy.
Thanks.
BenKus
November 29, 2010, 12:08pm
10
Well… The problem appears to be that your command line doesn’t match the package that you deployed. Change the command line to read “SSMSEE.msi” instead of “FoxReader.msi” and I think it will work.
system
November 29, 2010, 1:01pm
11
thanks Ben, I’ll try and tell result later.
and addition comment are still welcome.
