Hi I am trying to deploy a msi file through bigfix. I created a fixlet.
With these lines i can able to install appliacation but when i checked it is not installing for example it is not showing on add or remove section.
But when i run this msiexec command with admin rights on cmd there is no problem. If i run this msiexec on standart cmd screen it is not installaing. Normally bigfix using system user which has admin rights. But we couldnt figure out problem.
I’ve had to change the LoadBehavior in the registry for some office addins after using bigfix to run the install. May not be related but it could be worth looking at.
