More fun with GUIDs in relevance
(imported topic written by deschodt91)
Hello all,
I am trying to base some relevance off the existence of an uninstall string in the registry…
This type of relevance normally works great: exists key “blah” of key “HKLM\Software\microsoft\windows\currentversion\uninstall” of registry returns TRUE if “blah” exists… Great !
Problem is, again, I need to use a GUID for this specific case… So it’s same as above but using exists key “{02AF-5454545etc}” of key…etc…
That key exists, yet QNA returns FALSE every time - it’s a copy-paste job so it’s not a typo… I remember Ben advised me to use double “{{” in actions as “{” gets dropped, but that does not seem to do the trick either in relevance, QNA says FALSE, sorry, have a nice day… Hmmm…
Any ideas ?
Hi deschodt,
This should work in QnA every time:
q: exists key “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{210A2188-5796-4D64-812C-050463C34236}” of registry
A: True
q: exists key “{210A2188-5796-4D64-812C-050463C34236}” of key “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall” of registry
A: True
If you are using this relevance in an action, you need to escape the open “{” so that the action doesn’t get confused and think that you want to substitute relevance, so it would look something like:
waithidden msiexec -x {{210A2188-5796-4D64-812C-050463C34236}
So in the above example, there is no relevance substitution at all… but if you do want to substitute relevance in an action that contains “{}”, then you actually need to escape the “}” so that the action doesn’t get confused and close your relevance expression early:
waithidden “{value “UninstallString” of key “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall{210A2188-5796-4D64-812C-050463C34236}}” of registry}”
Fun stuff? Does that help?
(imported comment written by deschodt91)
It does, thanks… I have no idea why it did not work on that specific GUID I was using yesterday, but it works on others, so I guess I got unlucky trying a bad one as my first attempt !
