Modify right Click "Install BES Client" in Unassigned Assets
(imported topic written by vampd91)
Under Unassigned assets tab, you have the option to install BES client when you right click a asset. However, I don’t want to use the BES client installer provided by Bigfix. Can I change run a differnt program, ie .bat or different command? I’m guessing it’s a registry key, if it can be done.
maybe this will help
http://support.bigfix.com/bes/misc/customrightclick.html
…Actually, this is for the Computer Tab only is seems. This probably won’t be helpful.
