I have the following relevance that is returning the error: "the right operand of the ‘and’ must have type ‘singular boolean’ (it has type ‘singular integer’ now).
How can I get the check for a relay and the query for a file version to work together?
if exists relay service then (maximum of (if exists file (value of variable “ProgramFiles” of environment & “\BigFix Enterprise\BES Relay\wwwrootbes\bfmirror\downloads\sha1\c2e4dcc2ce4e3cfad844b53cd5847e942fc03814”) then “1703” as integer else if exists file (value of variable “ProgramFiles” of environment & “\BigFix Enterprise\BES Relay\wwwrootbes\bfmirror\downloads\sha1\fa65f9da96841a73c6ed0a4aa92a8596cbab2161”) then “1709” as integer else if exists file (value of variable “ProgramFiles” of environment & “\BigFix Enterprise\BES Relay\wwwrootbes\bfmirror\downloads\sha1\23637F78185AF32F905805396F100CB97A184256”) then “1803” as integer else if exists file (value of variable “ProgramFiles” of environment & “\BigFix Enterprise\BES Relay\wwwrootbes\bfmirror\downloads\sha1\481e839935f81d154cc383b209fa2f185ac02c6c”) then “1809” as integer else “0000” as integer)) else false
So you have to have the same types on both paths of a relevance statement. So you should work your logic to return either both boolean types or both integer types
My logic was wrong anyway. I was trying to find the maximum version cached. I just reversed my search order to look for the highest version first. It is not very elegant, but it will work. I am sure there is a better way.
if exists file (value of variable “ProgramFiles” of environment & “\BigFix Enterprise\BES Relay\wwwrootbes\bfmirror\downloads\sha1\c2e4dcc2ce4e3cfad844b53cd5847e942fc03814”) then “1809” else if exists file (value of variable “ProgramFiles” of environment & “\BigFix Enterprise\BES Relay\wwwrootbes\bfmirror\downloads\sha1\fa65f9da96841a73c6ed0a4aa92a8596cbab2161”) then “1803” else if exists file (value of variable “ProgramFiles” of environment & “\BigFix Enterprise\BES Relay\wwwrootbes\bfmirror\downloads\sha1\23637F78185AF32F905805396F100CB97A184256”) then “1709” else if exists file (value of variable “ProgramFiles” of environment & “\BigFix Enterprise\BES Relay\wwwrootbes\bfmirror\downloads\sha1\481e839935f81d154cc383b209fa2f185ac02c6c”) then “1703” else “none”
