Missing QnA on SuSE 8.1.551?
In the past with my v7 clients, I was always able to ues the following directions to run QnA on a Linux/Unix box. However, When I attempt to do it on a SuSE OS running the new 8.1.551 client, there appears to not be a ‘qna’ directory within /var/opt/BESClient/. I confirmed this one a second SuSE box as well. Has QNA been removed from the 8.1.551 client?
http://support.bigfix.com/cgi-bin/kbdirect.pl?id=347
I think you got the wrong directory.
QnA is in “/opt/BESClient/bin”, not “/var/opt/BESClient”.
QnA dir isn’t in my “opt/BESClient/bin” directory…
suse11:/opt/BESClient/bin # ls
1 XBESClientUI libBEScrypto_1_0_0_1.so rpm4stub.so xqna
BESClient XOpenUI libBESssl_1_0_0_1.so rpm4stub2.so
I have filed Bug#41746 for this issue.
thanks Lee. Are you seeing the QnA folder on your side though?
I don’t have a SuSE image, so I cannot verify.
Maybe someone else can double confirm.
I’m running TEM 8.1 on SuSE Enterprise 10 64-bit and qna is installed in /opt/BESClient/bin .
suse11:/var/opt/BESClient # ./runqna
./runqna: line 5: /opt/BESClient/bin/qna: No such file or directory
I have various SLE installs all with qna present. What SuSE are you running? I see that xqna is present so not sure why the other part isn’t there.
Have you tried removing the client package and re-adding it?
I’m running SUSE11 with the 8.1.551 client.
No, I haven’t tried that. how would I go about removing the package?
Download a copy of the BESClient locally that you wish to install to say your /tmp drive
Remove the BESAgent already installed - your masthead etc will stay present
rpm -e BESAgent
Install your new one
rpm -i /tmp/downloadedagentpackage
This will leave the agent not running so run startup
/etc/init.d/besclient start
The package should have installed and placed the binaries back intact. Just performed this myself and it installed qna
removing BESClient and reinstalling it worked. I now see the file 'qna" in /opt/BESClient/bin and my ./runqna works.
Once question though, why do you have to create the file “runqna”? Why is would that already exist if the values are always the same?
The main reason is that the script has to be specific generally to the type of shell you are running, making a generic one would be difficult though not impossible.
