Manual bigfix protection installation, workable?
As the title says, is that anyway to manually install Trend Micro using the installer “TMCPMInstaller_x64_11.0.0.3039_en.exe”? Sorry if it has been answered but I couldn’t seem to find the information. Thanks!
Hi @wonkt
We use the installer during the imaging of the computer, so yes it’s possible.
Then I have an open action with the settings so that when the computer comes online and connects to the server, it get’s the correct settings.
I’ve adjusted following task:
Core Protection Module - Endpoint Deploy (Version 11 Service Pack 1)
You need to adjust the action itself (delete the installer etc) and edit the relevance too (otherwise it will be non relevant all the time).
Greetings
Great info! I will give it a try, thanks.
