Location of system folder syntax
(imported topic written by TommyG91)
  1. When authoring fixlets, do I need to put in code to delete the install files after I run them? I don’t want to orphan install files on the clients.
  2. Can anyone help me with this syntax below? I don’t want to hard code the path to the system32 folder, as it’s not always the same.
This works:
move “__Download\file.exe” “C:\WINDOWS\system32\file.exe”
But this does not work:
move “__Download\file.exe” (location of system folder & “\system32\file.exe”)
Thanks!
Tom
(imported comment written by snoczp91)
Did you try %systemroot%\system32 ?
When you use Relevance expressions (“location of system folder”) in side of Actionscript you need to put the Relevance in curly braces.
Your move line becomes:
move “__Download\file.exe” “{location of system folder & “\system32\file.exe”}”
(imported comment written by TommyG91)
noah
Noah, thanks for the advice. It worked!
