Language Issue with "FixletDebugger-alpha2" & qna-7.0.9.164
Hello ALL
i download the new Fixlet Debugger tool and also the Qna newest Version and i face a strange Issue
Whenever i open any one of them and start writing in the “qna text area” or the “Action text area” , i found my PC langauge changed Automatically !!
  • I use on my PC on two langauage >> English(united state ) as default langauage & Arabic langauage ( Egypt )
  • This Issue was not and still not exist when use the Old version on QNA " qna-6.0.15.7 "
  • when i write the relevance script in Notepad and copy and paste it in the tool , it run normally , but also the language change automatically !
Can someone advise when should i do to solve this bug
Ahmed Hamed
(imported comment written by peterd91)
Ahmed,
When the language changes automatically, does it change to English or Arabic? What is your Default language set to?
I believe the language bar settings are program specific. If you want to stay in a specific language, try to go to the language settings > Default input language
Also, try to change the language to whatever language you want to use for these applications while the Windows Explorer is in the front active window. I don’t know why I’ve seen this to work, maybe because it’s the explorer that launches the other applications and they inherit the language settings…
I hope you find resolution soon.
Peter
Thanks Peter for Your Reply
my Default language is English > which is the defauly input language
and whenever i Write my first letter in the Fixlet Debugger , the language bar change to Arabic Automatically
and even if i manually changed it back to english , it return back again when i write any letter in the fixlet debugger !
