Kill running application - firefox
Close but not quite working. The taskkill will work as a standalone, but it is not working within the if then command.
// kill the firefox application if it is running
If (exists running application whose (name of it as lowercase is "firefox.exe)) then (“runhidden taskkill /f /im firefox.exe”) else nothing
// uninstall firefox
runhidden “C:\Program Files\Mozilla Firefox\uninstall\helper.exe” /S
In actions, the if and other flow control commands are different from relevance. Here’s the format from the
Action Guide
if {EXPR1}
statements to execute on EXPR1 = TRUE
elseif {EXPR2}
statements to execute on EXPR1 != TRUE and EXPR2 = TRUE
else
statements to execute when EXPR1 != TRUE and EXPR2 != TRUE
endif
So your action would be
if {exists running application whose (name of it as lowercase is "firefox.exe)}
endif
runhidden "C:\Program Files\Mozilla Firefox\uninstall\helper.exe" /S
That works. One final questions though, any idea why it is not accepting the /S at the end of the uninstaller? when I run the command “C:\Program Files\Mozilla Firefox\uninstall\helper.exe” /S from the command prompt, it works, but not through the fixlet.
nevermind, I got it to work using the command
runhidden {pathname of parent folder of regapp “firefox.exe”}\uninstall\helper.exe /s
Try using waithidden.
Also, you probably need quotes around your paths:
waithidden “{pathname of parent folder of regapp “firefox.exe”}\uninstall\helper.exe” /s
After a few tweeks, this is what I have:
// uninstall firefox if firefox.exe is not running.
If {not exists running application whose (name of it as lowercase is “firefox.exe”)}
runhidden “{pathname of parent folder of regapp “firefox.exe”}\uninstall\helper.exe” /s
endif
The problem now is that it is reporting back “Not Reported” when firefox.exe is running. I think I need an else statement in there to quit if firefox.exe is running.
