Hello,
I have one server (AIX VIO 6.1) that we are facing issues when setting up the relay for it to report to.
We stop the client and add/replace the config for the __RelayServer1 value but after the client is started again the config file is overwritten with default settings.
The only unusual thing in the logs is " Action site masthead keys are not compatible, starting client reset"
We have already replaced the actionsite.afxm many times (it is the same as the one on the BES Root Server).
What does this “Action site masthead keys are not compatible, starting client reset” mean regarding the logs?
Is this what is causing the config changes not to “stick”?
Current Date: March 28, 2017
Client version 9.1.1117.0 built for AIX 6.1 ppc64
Current Balance Settings: Use CPU: True Entitlement: 0 WorkIdle: 10 SleepIdle: 480
ICU data directory: ‘/var/opt/BESClient’
ICU init status: SUCCESS
ICU deployment character set: ISO_8859-1:1987
ICU local character set: ISO_8859-1:1987
ICU transcoding between deployment and local character sets: DISABLED
At 14:42:44 -0500 -
Starting client version 9.1.1117.0
FIPS mode disabled by default.
Cryptographic module initialized successfully.
Using crypto library libBEScrypto - OpenSSL 1.0.1h-fips 5 Jun 2014
Restricted mode
At 14:42:45 -0500 -
Beginning Relay Select
All help is appreciated.
