Is there a way to test fixlets (i.e. a fixlet debugger) on *nix systems?
I was looking to download a fixlet debugger for Red Hat so I can test my relevance statements before creating the actual fixlets… but it appears IBM only has fixlet debuggers for Windows… So, is there anything that exists for *nix systems?
It is built into the *NIX agents. Take a look at /opt/BESClient/bin. In there you’ll find:
qna (text debugger)
xqna (graphical debugger)
Good luck!
Awesome - I didn’t know that… Does that hold true for the Solaris agent too?
Yes. It will be in the bin directory.
See here for more info including a recommended variable to set to make it work properly:
http://www-01.ibm.com/support/docview.wss?uid=swg21506026
Not to bring up old topics… but I’m just now getting to the point where I need to start debugging fixlets on *nix.
I followed the instructions located here: http://www-01.ibm.com/support/docview.wss?uid=swg21506026 - I created the script and set the permissions… but whenever I attempt to run it, I get a the following message: LIBPATH=/opt/BESClient/bin: is not an identifier
Not sure what this message is trying to tell me…
