(imported topic written by John_Masters91)
I’ve just looked at the “Installed Applications - Windows” Property: -
(if (exists value “DisplayName” of it AND (length of (value “DisplayName” of it as string) > 0) AND (number of substrings " " of (value “DisplayName” of it as string) < (length of (value “DisplayName” of it as string)))) then (value “DisplayName” of it as string & (if (exists value “DisplayVersion” of it) then (" - " & value “DisplayVersion” of it as string) else (""))) else (name of it & (if (exists value “DisplayVersion” of it) then (" - " & value “DisplayVersion” of it as string) else ("")))) of keys whose (exists value “UninstallString” of it) of key “HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall” of registry
However… SOME of our apps do not have an UninstallString in the registry key mentioned but DO show in the add/remove programs list (this is by design!)
I can return JUST these easily enough by changing the above to read: -
NOT
But, this is not ideal… I would like both types of entry returned. If I remove “of keys whose (exists value “UninstallString” of it)” altogether, the only result I get it the text “Uninstall”
What do I need to do to get both? - aside from get myself on a rel language course!
