We are experimenting with wake-on-lan for BigFix Power Management. We have enabled at the console, and have designated a wake-on-lan forwarder for the subnet.
Successfully waking a device appears to succeed randomly.
We are using the same target device(s) for testing, and have ensured that wake-on-lan support is enabled in BIOS.
Sometimes, the device will wake up almost immediately. Other times, the device does not respond to the request at all.
I looked at the KB article for implementation, and I believe we are set up correctly. The fact that the wake-up sometimes works should be an indicator that the basic configuration is accurate.
I saw mention in another thread about having many devices on the subnet act as WOL forwarders. Is there a recommended number of devices? What is the impact of having a device set as a WOL forwarder? What is the network impact of having multiple forwarders? If I use a BigFix relay local to the subnet as a forwarder, shouldnât that be adequate?
