hi,
few weeks before we removed 2 windows servers in TEM console and also we removed that in ILMT data source group.
There is no initaite softwarescan,run and capacity , upload software scan Fixlets are running for that mentioned two servers.
Now the servers are not visible while pulling the reports for hardware scan data, but while pulling Full Capacity/Sub Capacity reports that two servers are reflecting with the comment"incomplete virtualization hierarchy".
can anyone please suggest how to remove the entries of 2 servers in other reports.
karthik.k
ILMT retains the scan history of deleted computers. The Capacity reports by default contain the last 90 days of data. If you Configure the View, you can change the time range to something like 14 days.
Note that IBM expects you to report PVU consumption every 90 days, and uses the highest value present in the report (aka High Water Mark) to compare with your purchased sub-capacity license amount.
So even when you remove a computer from your environment, it will contribute to your consumption calculations for at least 90 days thereafter.
Thanks ,now the servers are not reflecting after done the changes in configure setting.
