If not installed
Greetings all,
Can someone please help me add something to this, if java is not installed?
Here is my current relevance that displays the desired results:
concatenation ", " of names of keys of key “HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Runtime Environment” of registry
Except for the “” when java is not installed. I would like it to return “Not Installed”. Thank you in advance.
Alfred,
Adding just one character will make your property return nothing instead an error:
concatenation ", " of names of keys of keys “HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Runtime Environment” of registry
If you want it to return “Not Installed” instead nothing, you can wrap it in an if statement:
if (exists keys of keys “HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Runtime Environment” of registry)
then (concatenation ", " of names of keys of keys “HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Runtime Environment” of registry)
else (“Not Installed”)
Works like a charm, thank you jessewk.
