IEM connection error to DB2
(imported topic written by vorosp)
Hello,
After changed IEM’s db2 user password (because it was expired), the BESServer can not connect to database with following error after restart:
Startup failed: error testing database connection: Database Error: [IBM][CLI Driver] SQL30082N Security processing failed with reason “24” (“USERNAME AND/OR PASSWORD INVALID”). SQLSTATE=08001 (08001:4294937214)
I followed this documentation step by step:
http://pic.dhe.ibm.com/infocenter/tivihelp/v26r1/index.jsp?topic=%2Fcom.ibm.tem.doc_9.0%2Fwelcome%2Fwelcome.html
At restart password are not obfuscated and substituted again with
in the besserver.config file (it seems that everything OK with beswebreports.config file)
If I try to connect to databases manually, everything OK, no password problem.
Do you have any idea how it can solve this problem?
IEM version: 9.0.787.0
DB2 version: DB2 v10.1.0.2", “s121127”, “IP23394”, and Fix Pack “2”.
OS version: Red Hat Enterprise Linux Server release 6.5 (Santiago)
Thank you!
Pretty sure You have already opened a PMR or fixed the problem
but in any case here is a tech note about this topic explain how resolve the issue …
http://www-01.ibm.com/support/docview.wss?uid=swg21982500
