IE 7 issues with the BES Console -- workaround
(imported topic written by BenKus)
Our testing shows that Internet Explorer 7 will cause the BES Console to show certain errors. The errors are due to a change Microsoft made in the default security settings for applications that use some of the built-in IE components.
To fix this issue, set this value:
“HKLM\SOFTWARE\Microsoft\Internet Explorer\Main\FeatureControl\FEATURE_BLOCK_LMZ_SCRIPT”:“BESConsole.exe”
DWORD
=0
We will fix this issue in future versions of the BES Console, but since IE 7 was released very recently, this workaround should allow you to use IE7+BES Console without a problem.
And… We now have Fixlet to detect and fix this issue:
ID 428: “IE 7.0 May Cause Script Errors in the BES Console”
