I having trouble running this command in bigfix, Cscript.exe C:\WINDOWS\system32\iisext.vbs /EnExt “ASP.NET v2.0.50727 (32-bit)”, but when I logon to the server and run it from a cmd prompt it works, so I try using bigfix with the dos in front on the line but it did not work in bigfix, then I ran it using a batch file and it did not work using bigfix, but when I ran that batch file on the server it works, so how can I get bigfix to run the line?
