How to merge duplicated results from a plural relevance
(imported topic written by mingjie91)
Hi.
I have a relevance statement which returns a plural result. Is there any way to merge the duplicated values in the result, like ``select distinct’’ in SQL?
Q: …
A: 10
A: 10
A: 20
I want to have a result as:
Q: …
A: 10
A: 20
Thanks,
Mingjie.
q: unique values of (“10”;“10”;“20”)
A: 10
A: 20
Hi Mingjie. Welcome to the forum!
(imported comment written by mingjie91)
Ben.
Thanks for your response.
I have another question: does ``unique values of’’ support tuple?
q: ((10, 1); (10, 1); (20, 1))
A: 10, 1
A: 10, 1
A: 20, 1
But,
q: unique values of ((10, 1); (10, 1); (20, 1))
E: The operator “unique values” is not defined.
Jesse, thanks. :slight_smile:
Thanks,
Mingjie.
No, it only works on basic types.
You can do this though:
Q: unique values of (it as string) of ((10, 1); (10, 1); (20, 1))
A: 10, 1
A: 20, 1
Also note that unique values have an additional property ‘multiplicity’ that will tell you how many instances there are of that value:
Q: (it, multiplicity of it) of unique values of (it as string) of ((10, 1); (10, 1); (20, 1))
A: ( 10, 1 ), 2
A: ( 20, 1 ), 1
Great! It’s what I wanted to have. Thanks.
Mingjie.
