(imported topic written by lukibest)
i have this code :
DOS rename “C:\Windows\LG dir\screen.swf” {lines of file “name.txt” of folder “c:\windows\LG dir”}
how to hidden dos window? waitdetached doesn’t work
i have this code :
I believe :
runhidden rename “C:\Windows\LG dir\screen.swf” {lines of file “name.txt” of folder “c:\windows\LG dir”}
should work.
If that doesn’t work, you can try:
waithidden cmd.exe /C rename “C:\Windows\LG dir\screen.swf” {lines of file “name.txt” of folder “c:\windows\LG dir”}
Note that if "lines of file … " returns more than one result, this line will fail with a “relevance substitution error”.
