How to get Adobe product Serial number
I want to get an Adobe product Serial number using IBM Bigfix
is there any relevance please share us
Thanks,
Nagaraj,
Product version number or serial number ?
Serial number needed
Do you know how to retrieve this without using relevance ?
Once you know how to do that then it can be determined how to do that with relevance.
I don’t know how to get that normally, is there any way to find out please share any idea,
Thanks,
Nagaraj,
Serial numbers are usually stored in a very proprietary form to prevent gathering like this so its very unlikely you can do this.
