How to deploy VMtools using exe package from vmware in guest os
i’ve had much better luck just building install tasks from the downloaded tools than trying to go through the guest install.
I use the Windows Software Deployment Wizard to download the .exe to client and then run it with the following;
wait __Download\VMware-tools-10.3.10-12406962-x86_64.exe /s /v /qn REBOOT=R
For Tools 11 I used this so far:
setup64.exe /s /v "/qn REBOOT=R" /l "C:\Program Files (x86)\BigFix Enterprise\BES Client\__BESData\__Global\SWDDeployData\VMTools11Upgrade.log"
I wanted to use path relevance with “{parent folder of client folder of current site}__Global\SWDDeployData\VMTools11Upgrade.log” but i was erroring out somewhere.
For relevance, I like to use >= for the version:
not exists key whose (value "displayname" of it as string contains "VMware Tools" of it and value "DisplayVersion" of it as string as version >= "11.0.0.14549434" as version) of key "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" of native registry
(string value of select "Manufacturer from Win32_ComputerSystem" of wmi) contains "VMware"
architecture of operating system is "x86_64"
