This Path :
But * is versions and computer have different versions so, how to coding the script to get the value of this Path?
This Path :
not sure if you can use folder of folder since you are looking at the registry :-/
some Syntax:
Q:(windows of operating system) AND (exists files ("AppData\Roaming\BitTorrent\BitTorrent.exe";"appdata\roaming\utorrent web\utweb.exe") of folders of folders "C:\Users")
sorry bud, I wish I knew more >.< still learning to keep it all relevance. Iām sure powershell has a script to check and you can then write the output to a file. then have BigFix read the file
If SupersocketNetLib is the value then something like this
Q: values "SupersocketNetLib" of keys "MSSQLServer" of keys of keys "HKLM\SOFTWARE\Microsoft\Microsoft SQL Server" of (x64 registries ; x32 registries)
Thank You so much
Thank You so much
