system
January 19, 2010, 12:31am
1
hi there,
my latest attempts failed…
This is the results of my action script. It downloaded ok but didn’t copy the file across…
Completed download http://myserver:52311/Uploads/IMPAX.lnk
Completed continue if {(size of it = 1813 and sha1 of it = “3db6315938bbfa38aae3b515a93c4c9bfa9f030f”) of file “IMPAX.lnk” of folder “__Download”}
Completed if {(exists folder “c:\localapps”)}
Completed if {(exists file “IMPAX.lnk” of folder “c:\localapps”)}
Completed delete “c:\localapps\IMPAX.lnk”
Completed copy “__Download\IMPAX.lnk” “c:\localapps”
Completed else
Failed copy “__Download\IMPAX.lnk” “c:\localapps”
endif
else
dos Mkdir “c:\localapps”
endif
action script:
else
endif
else
Dos Mkdir “c:\localapps”
endif
BenKus
January 19, 2010, 7:54am
2
Try putting the filename in the copy command:
delete "c:\localapps\IMPAX.lnk"
copy “__Download\IMPAX.lnk” "c:\localapps\IMPAX.lnk"
else
endif
else
Dos Mkdir "c:\localapps"
endif
You can use the Fixlet debugger to help debug your action:
http://support.bigfix.com/fixlet/
system
January 19, 2010, 6:40pm
3
I think the logic here is a bit convoluted because if the folder does not exist, your file would have been downloaded, but never copied into the folder. I don’t think this is what was intended.
Try this instead:
endif
else
endif
copy “__Download\IMPAX.lnk” “c:\localapps\IMPAX.lnk”
system
January 19, 2010, 9:30pm
4
even simpler:
if {(exists file “c:\localapps\IMPAX.lnk”)}
else
endif
system
January 19, 2010, 11:28pm
5
Thanks guys, that works now and is simplified as well, however the fixlet debugger doesnt work for me:
Runtime Error!
Program: L…
This application has requested the Runtime to terminate in an unusual way. Please contact the application support team for more information.
system
January 19, 2010, 11:49pm
6
more information on the error:
“The exception unknown exception (0x40000015) occurred in the application at location 0x0052544c”
I unzipped it to 2 PCs and had the same error. The first time I just dragged the contents out to a folder and the second time I extracted and both had the same results.
system
January 20, 2010, 1:43am
7
Are you including the download command? Try running the action through the console rather than the Fixlet Debugger.
system
January 20, 2010, 11:48pm
8
No the Fixlet Debugger doesn’t go much past the initial window.
