(imported topic written by rmnetops91)
I need to determine the full executable path of a specific Windows service to perform an exists/not exists relevance comparison. Anyone know the syntax?
image paths of services
or for a specific service…
image path of service “BESClient”
(imported comment written by rmnetops91)
I saw that from another post, but I need to compare the actual full path of a service executable to something I define.
Like
If image path of service “BESClient” = C:\BESClient then true
image path of service “BESClient” as string = “c:\path\you\want\to\check”
Jessewk,
Thanks for the input. I didn’t have much luck with that relevance, but I did with this one:
exists image path whose (it contains “C:\Program Files\BigFix Enterprise\BES Client\BESClient.exe”) of service “BESClient”
image paths are often null terminated so that’s probably the reason it didn’t work with an exact match.
Your exactly right. In our case the service we were interested in, had %systemroot% specified in the image path, and the relevance check does not translate that into “C:\WINDOWS” like most applications within the OS. The relevance was checking for an exact match.
ah, in that case another trick would be to use the ‘expand environment strings’ inspector:
exists image path whose ((expand environment string of it) starts with “C:\Program Files\BigFix Enterprise\BES Client\BESClient.exe”) of service “BESClient”
