Help with parameter
hi
i try to crate file using parameter
parameter Destination= = “value “abcd” of key “HKEY_LOCAL_MACHINE\SOFTWARE\abcd\abcd” of native registry”
parameter Destination= = “value “my value” of key “HKEY_LOCAL_MACHINE\SOFTWARE\my software” of native registry”
createfile until end
[Paths]
Destination={parameter "Destination"
Source=C:\my source
I’m not sure why are you using parameters, but you could use something like:
Destination="{value "valueName" of key "HKEY_LOCAL_MACHINE\SOFTWARE\my software" of native registry}"
Just be sure to use the correct registry inspector.
https://developer.bigfix.com/relevance/guide/client/registry.html
Thanks for the help, it works, you helped me a lot
help plz wit analysis
(names of it, modification times of it) of files whose (now - modification time of it < 24*HOUR) of value “my value " of key “HKEY_LOCAL_MACHINE\SOFTWARE\mysoftware” of native registry”
See Help plz with analysis
CAN YOU HELP WITH THIS ONE ’
I HAVE 2 DIFFRENT FILE
1 -START WITH ABC
2 -START WITH XYZ
HOW CAN I SEE ONLY 1 FILE
