Help with a simple action script with relevance substitution
(imported topic written by cm6591)
I have an action script as follows:
parameter “new” = “{names of files of folder “C:\temp”}”
and the result is:
parameter “new” = “events_123events_1234events_12345”
the names of the files are:
events_123
events_1234
events_12345
Basically, I want each name to be assigned to a different variable. How can I do that? For example,
new1 = events_123
new2 = events_1234
new3 = events_12345
(imported comment written by cm6591)
I tried the following for this:
Q:item 0 of (names of files of folder “C:\temp”)
E: The tuple index 0 is out of range.
Not sure where am I going wrong with this?
Hi cm,
Unfortunately, you can’t set parameters to multiple values with a list like this…
What are you trying to do with these variables? maybe there is another way…
Thanks Ben. I think I have made some progress. But I need further help…
//this is giving me comma delimited results
q:concatenation “,” of (names of files of folder “C:\temp”)
A: events_123,events_1234,events_12345
T: 1.015 ms
//now i want to get the first item of the above results and I am getting an error. I don’t understand
Q:item 0 of (concatenation “,” of (names of files of folder “C:\temp”))
Hi cm,
“item” is used for “tuples”… as an example:
Q: item 1 of (0,1,2)
A: 1
But I am not sure how this relates to what you are trying to do (I am not clear what problem you are trying to accomplish).
Thanks Ben. I’m now able to get this to work
(imported comment written by jeremytoo)
cm, can you post your working code? It’ll help answer the question for someone searching the archives of the forum :slight_smile:
