Help creating Custom Copy of a Fixlet
Hello,
I’m very new to authoring/modifiying fixlets and could use all the help I can get!
Was testing fixlet ID 8091033 for Adobe Reader 9.3.3 security update and noticed it was changing some registry values located in HKEY_LOCAL_MACHINE\SOFTWARE\Classes\AcroExch.Document7\shell\open\command to point to Adobe Acrobat 5. Ideally I would like to copy the exsisting fixlet and add registry settings back to what they should be at the end of the fixlet.
Desired Settings:
HKLM\SOFTWARE\Classes\AcroExch.Document.7\shell\Open\command
Default
= “C:\Program Files (x86)\Adobe\Reader 9.0\Reader\AcroRd32.exe” “%1”
HKLM\SOFTWARE\Classes\AcroExch.Document.7\shell\Print\command
Default
= “C:\Program Files (x86)\Adobe\Reader 9.0\Reader\AcroRd32.exe” /p /h “%1”
HKLM\SOFTWARE\Classes\AcroExch.Document.7\shell\Printto\command
Default
= “C:\Program Files (x86)\Adobe\Reader 9.0\Reader\AcroRd32.exe” /t “%1” “%2” “%3” “%4”
If it’s easier, I exported the desired settings into a .reg that could be applied at the end, just not sure how and where it would look/be in the code of the copied and modified fixlet.
Any help would be greatly appreciated!
I didnt look through the Fixlet yet but you could create a custom copy of the Fixlet and add or replace the lines below
if
{not x64 of operating system
} regset
"[HKLM\SOFTWARE\Classes\AcroExch.Document.7\shell\Open\command]" @ =
"C:\Program Files (x86)\Adobe\Reader 9.0\Reader\AcroRd32.exe"
"%1" regset
"[HKLM\SOFTWARE\Classes\AcroExch.Document.7\shell\Print\command]" @ =
"C:\Program Files (x86)\Adobe\Reader 9.0\Reader\AcroRd32.exe" /p /h
"%1" regset
"[HKLM\SOFTWARE\Classes\AcroExch.Document.7\shell\Printto\command]" @ =
"C:\Program Files (x86)\Adobe\Reader 9.0\Reader\AcroRd32.exe" /t
"%1"
"%2"
"%3"
"%4" endif
if
{x64 of operating system
} regset64
"%1" regset64
"%1" regset64
"%1"
"%2"
"%3"
"%4" endif
Thanks for the reply!
I’m not sure I’m putting the code in the right place, as the settings are not taking. Target PCs are Windows XP SP3 machines.
here is the entire code, with your changes:
download http://ardownload.adobe.com/pub/adobe/reader/win/9.x/9.3.3/misc/AdbeRdrUpd933_all_incr.msp
continue if {(size of it = 8040960 AND sha1 of it = “0bc1c01fcf1e5c872c31b3f633428007438bd05e”) of file “AdbeRdrUpd933_all_incr.msp” of folder “__Download”}
waithidden msiexec.exe /p “__Download\AdbeRdrUpd933_all_incr.msp” REINSTALL=ALL REINSTALLMODE=omu /qn
delete __appendfile
appendfile REGEDIT4
appendfile
http://HKEY_LOCAL_MACHINE\SOFTWARE\Adobe\Acrobat Reader\9.0\AdobeViewer
appendfile “EULA”=dword:00000001
appendfile “Launched”=dword:00000001
appendfile
delete temp.reg
move __appendfile temp.reg
wait regedit -s temp.reg
// Disable the updater
// First, create an updater preferences file
delete __appendfile
appendfile <?xml version="1.0" encoding="UTF-8" ?>
appendfile
appendfile %temp%\Adobe\Updater6\aum.log
appendfile 2
appendfile 0
appendfile
appendfile 0
appendfile 0
appendfile 2008-07-01
appendfile 0
appendfile 0
appendfile 0
appendfile 0
appendfile 1
appendfile
appendfile 0
appendfile
appendfile
delete AdobeUpdaterPrefs.dat
copy __appendfile AdobeUpdaterPrefs.dat
// Now create a batch file that will put this in all users’ application data folders
delete __appendfile
appendfile @ECHO OFF
appendfile for /f “tokens=* delims=,” %%a in (‘dir %systemdrive%\docume~1 /b /ad’) do call :process “%%a”
appendfile goto :eof
appendfile :process
appendfile if
%1
== goto :eof
appendfile if
%1
== goto :eof
appendfile if
%1
== goto :eof
appendfile xcopy AdobeUpdaterPrefs.dat “%systemdrive%\Documents and Settings%~1\Local Settings\Application Data\Adobe\Updater6” /Y/I
delete AdobeUpdaterPrefs.bat
copy __appendfile AdobeUpdaterPrefs.bat
// Run the batch file
waithidden AdobeUpdaterPrefs.bat
//modify the registry to fit appropriate settings
if {not x64 of operating system}
regset
http://HKLM\SOFTWARE\Classes\AcroExch.Document.7\shell\Open\command
@ = “C:\Program Files\Adobe\Reader 9.0\Reader\AcroRd32.exe” “%1”
regset
http://HKLM\SOFTWARE\Classes\AcroExch.Document.7\shell\Print\command
@ = “C:\Program Files\Adobe\Reader 9.0\Reader\AcroRd32.exe” /p /h “%1”
regset
http://HKLM\SOFTWARE\Classes\AcroExch.Document.7\shell\Printto\command
@ = “C:\Program Files\Adobe\Reader 9.0\Reader\AcroRd32.exe” /t “%1” “%2” “%3” “%4”
endif
if {x64 of operating system}
regset64
@ = “C:\Program Files (x86)\Adobe\Reader 9.0\Reader\AcroRd32.exe” “%1”
regset64
@ = “C:\Program Files (x86)\Adobe\Reader 9.0\Reader\AcroRd32.exe” /p /h “%1”
regset64
@ = “C:\Program Files (x86)\Adobe\Reader 9.0\Reader\AcroRd32.exe” /t “%1” “%2” “%3” “%4”
endif
action may require restart “0bc1c01fcf1e5c872c31b3f633428007438bd05e”
thanks in advance!
EDIT: Would it be easier to export the desired registry settings to a .reg file and have the fixlet run the .reg file at the end? If so, how would I do that? -thanks
Where you put my code looks fine
Download the Fixlet Debugger and choose “New Action Tab” paste your code in and run it
http://software.bigfix.com/download/bes/72/FixletDebugger-7.5.0.933.zip
The code I gave you sets the registry entrys and was tested in the Fixlet Dubugger…
I dont have any relevant systems for that fixlet
Try running it through the Debugger and see if you get the desired results
