I created a multiple action group and pushed 15 critical windows patches to a target server.
I notice the patches download is very slowly and they are installed one by one automatically.
I think it’s cost a lot of time, maybe 24 hours for installation.
Can you introduce me the fuction of patch update? When I execute a action to push a patch, would the package be download to BES client directly? Which directory is the installation package restored? What is the BES Tier 2 relay’s responsibility? Does the BES Tier 2 relay get patches first and then push to the client?
Can you tell me the path of the download packadge? The sever is updated but I can’t find the installation packadge. Did bigfix client delete the packadge after installation action?
I There is no reference in Admin guide. Pls kindly help me on this. Thank you!
Yes. We want to find a method to download the patches first without installing them. Because, we have a window(about 2 days) to install the patches and reboot the production system. If we let the BES client to download patches and install them one by one, it will cost a lot of time as the result of our bandwidth.
Would it be possible to put a BigFix Relay “closer” to the computer so that they will have faster bandwidth to download the files (which will be automatically cached on the relays). This would be the easiest and most common way to address this issue.
And what sort of bandwidth speeds are you talking about? I am shocked that it takes so long for you to transfer the files…
