(imported topic written by boostaz191)
substrings after “=” of (selects (“ProviderName from Win32_LogicalDisk where ProviderName =’\ServerName\Sharename’”)of WMI as string)
PS. this is for an analysis
(imported comment written by boostaz191)
Ok here is a problem:
Statement:
exists (substrings after “=” of (selects “ProviderName from WIN32_LogicalDisk” of WMI as string as lowercase)) whose( it contains ("\server\share" as lowercase))
In QNA this works fine in my analysis it does not
QNA Results:
Q: exists (substrings after “=” of (selects “ProviderName from WIN32_LogicalDisk” of WMI as string as lowercase)) whose( it contains ("\Server\Share" as lowercase))
A: True
Analysis Results:
System Name
HQZ0RC1 False
probably a user context issue. Most likely that share doesn’t exist in the SYSTEM context. Just a guess though.
Ok? I unfortunately dont know the difference? can you elaborate…
The relevance debugger will be running in your user context. The client runs in the SYSTEM context.
Your user has a share \server\share
The SYSTEM user does not have a share \server\share
I’m don’t know if you can get WMI to evaluate using a different context.
so could i use the run as current user option?
Hey boostaz1,
I suppose you could make a Fixlet that ran an action like:
waithidden runascurrentuser.exe cmd.exe /C net share >> C:\sharelist.txt
And then write relevance to parse the file…
