Failover clustering
Anyone successfully deployed a MS failover cluster (2 nodes assumed) with shared disk for 11.0.4+ of Bigfix?
What steps did you follow?
I see the setshareableserverdatapath support here, BESAdmin Windows Command Line
Did you crash and burn on WebUI? The reason I ask is WebUI is really sensitive to the keys. Prior to this quirky failover cluster support, you had to decrypt the keys located here:
Directory of D:\Program Files (x86)\BigFix Enterprise\BES Server
01/22/2021 04:48 PM 1,926 EncryptedAPIServerKey
01/22/2021 04:48 PM 1,850 EncryptedClientCAKey
05/13/2024 02:44 PM 1,926 EncryptedExplorerCAKey
01/22/2021 04:48 PM 1,926 EncryptedPlatKey
01/22/2021 04:48 PM 1,850 EncryptedServerSigningKey
01/22/2021 04:48 PM 1,926 EncryptedWebUICAKey
then copy them over to an empty ?:\”Program Files (x86)\BigFix Enterprise\BES Server” folder followed by re-encrypting them using serverkeytool.exe (created BEFORE starting the install of BF on the 2nd node) or you face complete database corruption and guess what? Now you start over after restoring your BFEnterprise DB.
I don’t know if this can help: HA and DR configurations
