I use version 9.2.6.94 of IBM Bigfix,
When I run the script on cmd I get rc = 10 But when I run it on bigfix I get RC = 0 So I can not get the right result on console. I run this job on 24 machines, but only 1 machine is returning wrong value.
Any ideas on the subject? Thanks for your help
–When run with cmd
run:“C:\WINDOWS\system32\windowspowershell\v1.0\powershell.exe” -noprofile -executionpolicy bypass -file “C:\aktar\pgm\PaktarTool.ps1” \server\43a971edfead379c556a0cfbc35ac51f\packet.zip
Error :Package record not found.
run : %errorlevel%
‘10’ is not recognized as an internal or external command,operable program or batch file.
–When I run with bigfix
Code
action parameter query “PaketAdi” with description “Paket-Adi FullPath Giriniz”
//THIS TASK WILL DOWNLOAD AND EXECUTE A POWERSHELL SCRIPT
if {exist file “C:\IEM\Tools\vgmetadata.cre”}
parameter “PowerShellexe” = "C:\WINDOWS\system32\windowspowershell\v1.0\powershell.exe"
waithidden “{parameter “PowerShellexe”}” -noprofile -executionpolicy bypass -file "{(value of setting “IEM_PKTAKTAR” of client)}\MapDrive.ps1"
waithidden “{parameter “PowerShellexe”}” -noprofile -executionpolicy bypass -file “{(value of setting “IEM_PKTAKTAR” of client)}\PaktarTool.ps1” {parameter “PaketAdi”}
endif
setting “Last_action_RC”={(exit code of action)} on “{now}” for client
exit {(value of setting “Last_action_RC” of client)}
LOG
Command succeeded (Exit Code=0) waithidden “C:\WINDOWS\system32\windowspowershell\v1.0\powershell.exe” -noprofile -executionpolicy bypass -file “D:\aktar\pgm\MapDrive.ps1” (action:40390)
At 16:38:39 +0300 - actionsite (http://bigfixServer/cgi-bin/bfgather.exe/actionsite)
Command started - waithidden “C:\WINDOWS\system32\windowspowershell\v1.0\powershell.exe” -noprofile -executionpolicy bypass -file “C:\aktar\pgm\PaktarTool.ps1” \servera\43a971edfead379c556a0cfbc35ac51f\packet.zip (action:40390)
At 16:38:40 +0300 - actionsite (http://bigfixServer/cgi-bin/bfgather.exe/actionsite)
Command succeeded setting “Last_action_RC”=0 on “Thu, 25 May 2017 16:38:41 +0300” for client (action:40390)
Command succeeded (0) exit {(value of setting “Last_action_RC” of client)} (action:40390)
