Exists relevance not working
I have a fixlet that modifies the registry. To be relevant, the host PC has to have this file on the file system.
C:\Windows\System32\winexit.scr
My relevance is: "exists file “C:\Windows\System32\winexit.scr”
This evaluates to False, though the file is actually there. Is there anything else I can try?
If this is a 64 bit machine then you’ll want:
exists x64 file "C:\Windows\System32\winexit.scr"
Awesome! That worked. Thanks! Why would similar relevance, without the x64, like this work on other fixlets?
For reference, please see https://www.ibm.com/developerworks/community/wikis/home?lang=en#!/wiki/Tivoli%20Endpoint%20Manager/page/Using%20WOW64%20Redirection
Great information. Thanks!
You need to do the following to check both the x64 system location as well as the x86 system location:
exists (x64 files "C:\Windows\System32\winexit.scr";files "C:\Windows\System32\winexit.scr")
Or
exists file "winexit.scr" of native system folder
I’d prefer this check because it will also give a false in the case that winexit.scr was mistakenly placed in c:\windows\syswow64 instead of \windows\system32 (perhaps because a prior BigFix action to put the file in system32 did not account for the 32-bit redirection)
I forget about native system folder.
This would be redundant, but you can do something like this:
files of (native system folders; system folders; system x64 folders)
If you just care if something exists at all, and your not overly concerned about where:
files "winexit.scr" of (native system folders; system folders; system x64 folders)
So many ways to do the same thing. It is a blessing and a curse.
Thanks everyone! I appreciate all of the responses.
