I installed the BigFix Excel Connector 3.3.2 on my Windows 7 64-bit with Office (Excel) 2010 installed.
When I open Excel. I get the following error message:
Detailed technical information follows:
(Inner Exception)
Date and Time: 06.02.2013 15:03:05
Machine Name: xxx
IP Address: xxx
Current User: xxx
Application Domain: D:\Users\xxx\AppData\Roaming\BigFix Enterprise\Tivoli Endpoint Manager Excel Connector 3.3\
Assembly Codebase: file:///D:/Users/xxx/AppData/Roaming/BigFix Enterprise/Tivoli Endpoint Manager Excel Connector 3.3/AddinExpress.MSO.2005.DLL
Assembly Full Name: AddinExpress.MSO.2005, Version=6.4.3056.2005, Culture=neutral, PublicKeyToken=4416dd98f0861965
Assembly Version: 6.4.3056.2005
Exception Source: Interop.Excel
Exception Type: System.Runtime.InteropServices.COMException
Exception Message: Old format or invalid type library. (Exception from HRESULT: 0x80028018 (TYPE_E_INVDATAREAD))
Exception Target Site: get_Version
- Stack Trace ----
Excel._Application.get_Version()
AddinExpress.MSO.2005.DLL: N 00000 (0x0) JIT
BigFixExcelConnector.FormWizard…ctor()
AddinExpress.MSO.2005.DLL: N 0462 (0x1CE) IL
BigFixExcelConnector.AddinModule.AddinModule_AddinInitialize(sender As Object, e As EventArgs)
AddinExpress.MSO.2005.DLL: N 0001 (0x1) IL
AddinExpress.MSO.ADXAddinModule.Extensibility.IDTExtensibility2.OnStartupComplete(custom As Array&)
AddinExpress.MSO.2005.DLL: N 0572 (0x23C) IL
(Outer Exception)
Machine Name: xxx
IP Address: xxx
Current User: xxx
Exception Source:
Exception Type: AddinExpress.MSO.ADXExternalException
Exception Message: An error has occured in the code of the add-in.
Exception Target Site: Object reference not set to an instance of an object.
- Stack Trace ----
any ideas?
Thx in advance!
