I’m with the problem that was reported earlier.
to run the Fixlet the failed item:
to continue if {exit code of action = 0}
Could help me what should I make?
Sorry, but I think you’re going to need to provide a lot more context here. Could you please describe what you’re trying to do at a higher level?
You’re referencing something that was reported earlier – can you link to that?
I am trying to setup Remote Control Server for Windows and I am in the early stage where I chose to be installed on SQL.
The job is created but however when running the fault in the item noted above.
