Error running task RelayNotifier6: HTTP Error 56: Failure when receiving data from the peer: Received HTTP code 403 from proxy after CONNECT
I am seeing this error on my main IEM server running 9.1.1117. This is a frequent error and I am not able to track down where the error might be originating from. THe RelayNotifier goes from 1 to 10. Any knowledge would be greatly appreciated.
Troy
The different numbers directly after RelayNotifier is referring to the thread number.
Relays send notifications to each other (and the Root Server) when there is a new site version, forwarding wake-on-lan requests, forwarding registration requests, or when a download is available.
Aside from these error messages, have you noticed any impact in relation to general usage from the Console and/or RESTAPI?
There were no other issues I could identify. Just this log file entry which I had seen in no other version of TEM. Thank you for your response.
I am seeing the same issue within my BESRelay logs from the BES Root Server. Any fixes or impact for this? Is just that the relay cannot be notified ?
May be this can use
http://www-01.ibm.com/support/docview.wss?uid=swg21973313
Thanks,
Nagaraj.
