Duplicate Clint Setting
We are using the client setting _BESClient_Report_MinimumInterval and set the value to 120. Recently a action was run to set the value to 600. What the end result was we now have two _BESClient_Report_MinimumInterval settings on our boxes one with a 120 value and the other with a 600 value. Curious which value the client will use? Is it possible to write a task to remove the one with the 120 value?
Are you sure they’re exactly the same? One or the other may be misspelled. I’m not certain whether mixed-case is considered the same or not.
A leading space before the first “_” has caught me out in the past
