I am currently having a problem setting up a distribution for XP with the wizard. I am trying to setup for a simple, one file executable. I go through all the steps, and when the Wizard finishes archiving, I receive a pop-up box, with the message, “Problem occurred when uploading file: .”
I am wondering if the problem is the BigFix Console doesn’t have enough memory, since I am running the BigFix Server and Console inside a VirtualBox VM.
I think you may be correct in the amount of Free Space on the server. I setup the Win2003 server inside a VM and it probably doesn’t have enough space. So, I’m now going to see if putting Win2003 on its own partition without a VM does the trick.
