Disabling Wireless
(imported topic written by balexph3291)
I need to figure out if Big Fix can determine if a system is connected through the wired network and disable the wireless if enabled. So that both aren’t running at the same time for security reasons. If not I would prefer to disable the wireless card or services anyway.
Does this help:
http://forum.bigfix.com/viewtopic.php?id=613
(imported comment written by balexph3291)
Thanks, it may point me in the right direction.
If you find a way to do this, can you report how you did it back here? We’d be interested in that as well.
Link no longer exist
